I'm a retired Nissan Master Tech and I started in Nissan in '86, so I'm been around a few of these engines. The stock Hitachi is a good carburetor and most of the problems that people have with them is because they aren't familiar with them. A lot of people and mechanics grew up working on Rochester's and Holley's, etc., but they Hitachi's are a little bit different. You don't mention if you are having any problems with it or not or if you are looking to upgrade the performance. If it's working well, leave it alone and save your money. If the factory carb is working well, there is no other carb that is going to make it run any better. The same goes for the ignition box. The factory system, as you know, already has a dual ignition system with 8-spark plugs and two coils; do you really think it needs any more spark than that? The Japanese know what they were doing when the built their engine backs then. The NAP-Z engines were really interesting in their design for their time. The NAP-Z engine was developed with Hitachi and was designed to facilitate a lot of EGR flow but still have good fuel mileage and power and it also has a Hemi-head. They were also durable. Occasionally, you might run into one with a blown head gasket between adjacent cylinders or run into one with an intake gasket leak, but they were about as solid as any engine around in its day. Unless you are going to full-bore, performance makeover, there's really no sense to go with anything else but stock parts.
