I got my Greddy oil filter block today. I must say it is a nice looking unit. I ordered it from www.nipponpower.com cost me about $65 with out shipping. The part number I got was 12002734 and it is "Type C" this is the one that fits the GA and its 3/4-16UNF filter thread. If you get one make sure it is this one. You do not want to get the SR20DE one becasue I think their filters are 20mm. The one I have will also fit Toyota's.
Good news:
3 ports, 1 M12X??, 2 1/8"BSPT
Simple and effective(KISS)
Small, about 3cm thick and about 8cm at its widest point
Bad news:
I was told the ports were 1/8"NPT just like my Autometer senders. Instead they seem to be 1/8"BSPT.
Can not use OEM GA filter becasue the gasket does not seem to have much to seal on. Will need filter with bigger(diameter)gasket.
Ok so, I was a little miffed about the port size. No worries though as I just happen to have a 1/8"NPT tap. I retapped the holes with no problem and the senders fit great. There was not even a need to drill.
I like the idea of 3 ports, 2(1.8"NPT) for gauges and 1(M12X??) for possible oil-to-turbo.
Here are the pics. If you have any questions, just ask
Note: that is a temp sender sticking out of it in the second pic. I would not suggest using that port for a temp sender as it "shrouds" the sender. Use the one on the side instead(first pic)
Good news:
Bad news:
