question?? maybe sum of you guys can give me more help, i just got a whole new suspension Intrax springs(2 "drop) and Cambers and KYB's, just the other day i added my rims and the rear is touching my struts i could't even reverse?? do you think it could be the cambers that were adjusted slightly too far in, cause my rims are really tucked... should i put back the original spindle bolts?? will that take it back to its original place?? Let me know...
thankx
PB JELLY TIME!
SERialThreatz, not rim size, tire size ###/##/###
Yeah, on a 7" wide wheel, you are probably running at least a 205 width tire. The offset on the wheel is probably 40mm. You will have to put spacers behind the wheel. 4-5mm should do it, I think. Some people can run 205's w/o rubbing but a lot have to have spacers.
