Hi all,
I have an on and off problem with my rear left break light I changed all the bulb and cheked the fuse but the problem is still there… anyone have an idea? Also, I will be changing my gas filter, do I need to know or do anything else, other than bleeding the gas lline?
thanx
Discussion Starter · #2 ·
did you check all the wiring connections to the light? also the socket might be toasted, causing it to work like that.
Still moderating..sorta
I've changed the fuel filter and it's easy. Just remeber not to store the old filter in a plastic bag. The gas melts the plastic.
