I’ve noticed some oil residue around the fill plug on the rear differential. Had it changed around a year now. Just happened to see this today and did not really notice this before.
No leaks or drips though. Vehicle has 176,000 miles. No differential noise either.
Discussion Starter #3
Put some anti-seize lubricant on the threads of the plug.
Thanks Rogoman, I removed the plug and put the lubricant on the threads and tightened back. Just hoping I don’t see anymore residue.
Is there any other way oil can sweat on the face of the differential in that area?
Nothing is coming from around air tube either. I assume the plug as I changed fluid and year around and seepage is around area of that plug.
NF Mod/Nissan Master Tech
Actually, you're supposed to put RTV sealant on the threads of the fill and drain plugs. If my memory is correct, the torque spec is 50 PSI.
