E
Eric
·Guest
Just wanna make sure I fine on everything for the rear drum to disk swap on my B13.
I have the following parts:
SE-R (B13)calipers, rotors, pads, spindles, e-brake lines and clips, ss brake lines, m/c. That should do it from what I've been told. Also I know that it most likely doesn't make a difference but does it matter if the spindles are from a SE-R with ABS? I know that it didn't with the NX2000 brake swap seeing as the calipers were ABS equipped. Also I got an NX2000 brake booster but it was the same as my stock booster. Thanks....
