1 - 8 of 8 Posts
I got a 95 HB thats 2-wheel drive automatic 4 cylinder. Its leaking antifreeze like crazy it coming from right in front of the transmission. a guy told me that the head gasket is blown and thats what causing it. Both my motor mounts are broke and i think its got the hose in a bind so whats yalls thoughts and what all do u have to do to change the head gasket.
let a professional do it. you need the head to get planed, and drilled at a machine shop. and in front of tranny? try look at the water pump its on the front cover in the middle
I found this sevice bulletin put out by Nissan.
Buyer's Alerts
Nissan Hardbody pickup, 1994-1997
Moisture in the distributor (possibly caused by a poorly designed distributor cap) may lead to various driveability concerns such as misfiring (TSB NTB00-086, Oct. 2000);
corrosion at the high mount stop lamp can be addressed by a new gasket(NTB99-068, Sept. 1999);
poor idling after when the engine is cold may be resolved by a new EGR (exhaust gas recirculation) valve (NTB97-100, Jan. 1998);
poor or no FM audio reception may be traced to condensation which has caused the tuner pack on the head unit to fail (NTB98-014, March 1998);
a new intake manifold and engine computer may address an engine misfire/rough running condition in cold weather caused by ice forming on the tip of a fuel injector during engine warm up (NTB96-114, Dec. 1996);
a transmission whine noise may be caused by a lack of lubrication to the main and counter drive gears (NTB97-018b, May 2000);
a rattle noise may be caused by excessive clearance between the piston pin and the piston, calling for a set of four new pistons, connecting rods and connecting rod bearings (NTB99-058, Sept. 1999);
water may leak through the rear sliding window, calling for a new window (NTB96-055, May 1996);
trucks with a manual transmission which surge or stumble may need a new engine computer (NTB98-026a, April 1999);
coolant apparently coming from the head gasket may be traced to the threaded blind plug (NTB95-087, Sept. 1994).
1 - 8 of 8 Posts
