When I’m driving it makes a random beeping sound for no clear reason, no lights or warning signs. It beeps like 5-10 times then stop. After about a minute it starts again. It’s not the seatbelt or key. Do you have any idea what it could be?
Hi,
I have Nissan versa 2009.
After I replace the steering wheel, the abs light is on everytime that the wheel is moving.
If I will drive straight from the beginning of the drive, the light will stay off.
I tried to reset the abs light but its not helped.
How can I fix it?
I own a 2007 Nissan Versa I just replace the clutch master cylinder and the end that goes through the firewall and attaches to the pedal Just Clips on unfortunately my new clutch master cylinder will not stay clipped on did I miss something when putting it together or is this a common problem
So, I've been using the key interlock cable under my gear shift (or the ignition shift release lock cable) (It's on the right side and has a white cable with notch that I use my finger and pull toward back of car and it releases my key)orever now because it's broken, and my keys won't release...
So check this out. My check engine light came on a couple days ago so I stopped at Checker Auto and checked the code. The code that shows up is P0705 - Transmission Range Sensor Circuit Malfunction (PRNDL input) – I called The Nissan dealer & they said that since it’s a transmission problem I’m...
Purchase used 2014 Nissan versa and after running ok I have engine light on.
From day 1 the engine idle was bit around 600 to 500 rpm after warm up only in drive when stopped at stop lights and etc. Didn't take much consider at the time however, when weather got cold with lights and heater on...
Nissan Forums is the go to place to talk about your favorite Nissan model, including the Rogue, Maxima, Altima and even sports cars like the 370Z and 200SX.
