Hi all!
I'm newly a proud owner of a Qashqai, (face-lift 2010) but the LCD radio screen is so bad, it's there and after half an hour nothing at all, and the sound has started cutting out, and I have to reboot the system for it to work again...any tips, tricks or ideas?
TIA
Chances are it's a Bosch Navi, so you might want to see if the dealer has any updates for it. We had similar units here in the 'States on '13~'15 Altimas which had some awful bugs in the early firmware, causing blackouts, reboots, and locked-up touchscreens. If it's shot and you need to find a replacement, the best way is to get the Nissan part number off the top label and google it. Popping the panels around the radio is simple and requires no tools except a plastic prybar, see this video:
Once the upper panel with the center vents is removed, you can see the label. For a Navi, the p/n will be 25915-something.
