i have a large backround in car audio and stereo stuff but i can't figure this out there is nothing rong with the radio everything worked fine till about a week ago when i switched out the alternator now as i drive if i step on the gas to hard the radio shuts off i was wondering if anyone knew y thank you
Make sure the belt is tight, and not glazed. That will cause a slip, when you hit to throttle hard. If the belt is shiny or cracked, clean the pulleys and put on a new belt. When it slips, you will have a voltage drop.
Good Luck
