1 - 7 of 7 Posts
ok so im sure there is already a post about this but my 95 nissan 200sx is leaking radiator fluid somewhere... i cant find out where though and it is pissing me off... i had a compression test done on it and it is NOT leaking from what i can tell by the compression test.... but i AM still losing fluid somehow someone please help
who needs clearcoat
Check the heater lines (passenger side firewall) or there are a ton of coolant lines that run under the intake manifold that suck to get to. Can you see it leaking after you get out? Is it a fast leak or just like a top-off-once-a-week leak?
2018 Nissan Pathfinder SL
check the floor on the passenger side front footwell for coolant....
yea i know about the weeping hole or w.e. but idt that is it either ... and no its not a fast leak it is like i have to add coolant to it like every 2-3 weeks... nothing to serious except i know its escaping from somewhere...
yeah, if it's not leaking from the radiator hoses, then it's most likely from water pump. remove the splash shield from underneath the car, run the engine a bit, then see where the drip's coming from. I had a leaky water pump which slowly leaked antifreeze when engine's running. I had the water pump replaced and it solved the problem.
How do you know it's leaking? is there a puddle under the car when you park it? Or does the coolant just go low? Do you physically see leaked coolant somewhere?
It might not be leaking at all, but rather is getting burnt in the engine, which could be a much more serious problem.
1 - 7 of 7 Posts
