Hey all I hope someone can help with this problem!
I woke up to a rude awakening today and noticed a puddle of coolant under my 1995 Maxima. I poured some water into the radiator to see if there were any leaks and right away i saw small stream of water coming on the transmission side of the car right by the oil pan. To be more exact its coming between a crevasse of the back side of the oil pan. I hope someone can be of some help my guess is a bad water pump. And if so if there any step by step procedures out there for it
well water pump are located at the other side of the transmission though.at the timing chain area.do check the a/c water hose that control the cabin temp.and also there are lots of hoses around there as well out fromthe engine
