1997 200SX
I have a pretty good psf leak coming from a hole in one of the steering gear boots which I recently replaced. Is it normal to have psf inside the boot? If not, what needs to be replaced? A seal? The steering gear?
Thanks
Steve
1997 200SX
Thanks
Steve
I have some psf leaking from mine as well, but its coming from old hoses, at the reservoir tank and pump. This link has the hoses if you need them. I was not able to find any other place besides a dealer that had pre-shaped hoses that you don't have to cut. And hopefully when I replace these hoses I don't find any other leaks either. I hope this helps. G Spec Performance - Steering
