1 - 8 of 8 Posts
Hi everyone,
I have '97 Sentra with manual tranny and sometimes when I shift into the 2nd gear it grinds a little bit. The mileage is 58K. I just wanted to know - is this a common issue with Nissan's manual transmissions? Does syncros often wear out at such mileage?
What's the price to rebuild a tranny?
Thanks for the answers.
NF's Offical Post Whore
my 2nd has been grinding for quite a bit now but and my tranny fluid is full. I think it might just be the way I hit second or whatever. I'll look into that solution tho, thanks
Sadly enough, every car I've ever owned was a manual BUT my 200sx (/cry) but every one of them have had problems in second gear (not bad, just acts like you miss a gear or let out the clutch before getting the gear seated) after about 60-70k on the odometer, all different makes too so not one particular company, in every case it was the synchros but changing the fluid regularly does help significantly.
So, am I gonna drive another 50K with this grinding (it's only sometimes)? As far as I understood, this is quite common?
Paging Mr. Herman
Does it grind all the time? If that is the case I would probably check it out, probably not serious but constant grinding can't be all that good.
I am reminded of my old Eclipse that would constantly grind into 2nd whenever the car was cold. I don't know if this has anything to do w/ your problem but I thought I'd throw it out. Sorry not much help.
VK, my car does the same thing, i ordered ES shifter bushings and a pacesetter short shifter should get here some time in this or the next week, ill let you know if they help
To Zimmy - thanks, it will be interesting to find out.
To zeno - no, it does not do it all the time. Sometimes it does it when the car is cold, sometimes when it's warm. It does it mainly after I accelerate quickly on the 1st gear and then shift into the second.
1 - 8 of 8 Posts
