The crankshaft is the weaklink in my set-up (and transmission). Upgrade those and 550whp is possible without NO2. I did run about 26psi thru it for a very short run and it held.
Here's a near complete mod list if it helps;
Turbo Setup:AEBS ductile iron sleeves (closed deck),Pauter rods (4mm longer) made by special agreement with JWT when they lost a Crower rod designed for them,ARP rod bolts ,Arias 8.5:1 pistons (with spiral-locks), JWT custom ground camshafts, JWT valvesprings, Bowl porting and new valve guides/seals, AEBS head studs, AEBS main studs, Oil galleys and bearings modified on block, Brand new Nissan crankshaft, New bearings, seals, o-rings, and timing components, Fully blueprinted bottom end, Block was acid dipped and cleaned also line bored JWT Balance shaft removal kit, Billet fuel rail, Removed butterfly valves, KA24DE throttle body, Custom alluminum gas pedal conversion (B15 SE), New B15 SE throttle cable, Crank trigger TIG welded to crankshaft pulley with alluminum bracket for Crank trigger sensor, 3-bar MAP sensor (29psi of boost- readable), Electromotive TEC III standalone, TEC III DFI coil packs, Manifold temp sensor,Coolant temp sensor (factory ga doesn't work, and not a concern), Wideband 02 sensor setup (can datalog on the TEC III), Custom MSD plug wires, Walbro 255lph pump, MSD 72lb injectors and clips, Custom TEC III wiring harness, Super Sequential blow off valve, 2" and 2.5" intercooler piping, Spearco bar and plate intercooler with cast tanks
Alluminum mounting brackets for intercooler, TIG welded schedule 40 turbo manifold, GT3540 ballbearing turbocharger (with Precision T3 and T04E housings), Tial 38mm wastegate with dump tube 3" downpipe,
3" exhaust with stainless muffler, JWT alluminum flywheel , JWT heavy duty clutch and pressure plate (good for 600whp), Perma-cool electric fans,
New 2003 transmission, Filled in motor mounts, Fuel return line setup, Aeromotive fuel pressure regulator, B15 SE fuel pressure sending unit/canister,
HKS EVC EZ boost controller, Autometer boost guage, Autometer oil pressure guage, Autometer EGT guage, Custom guage mount (where the factory stereo was), Red top Optima battery, Remote mount kit for the battery (puts battery in the trunk), Stainless steel braided oil feed line and drain line
Boosting 10.5# daily for 330whp
391whp 330trq @ 17# with Sunoco94 **Mustang dyno #'s
