41 - 60 of 64 Posts
do you have the headers and downpipe too or just the exhaust
I just have the exhaust. Was kinda thinking about getting a header, but probably won't, at least not right away.
im also assuming im going to go with the 00-01 model of the exhaust?
Yes, sorry, the one you're looking for is the 00-01 SE 2.0 Sentra exhaust.
Hi all, I have posted 2 previous threads regarding QG16DE modifications but sad to say, no one replied to my thread. But anyway, I am already did the I/H/E setup on my QG16DE namely AEM CAI, 4-2-1 extractor with 2" downpipe setup. The catalytic convertor was also removed and the stock centre and rear mufflers are replaced with 2" free flow mufflers. I am also using the Unorthodox crankshaft pulley. But however my low end seems to be very laggy and the power will only comes in after the 4k rpm zone. I have tried advancing my ignition timing with a CONSULT but it doesn't seems to improve alot. Is there any other ways I can do to improve my low end? I will greatly appreciate if someone can enlighten me. Thanks in advance!
I have a 2005 Sentra 1.8s
I want to start my mods out slow.
I see you say go with the cold air Intake and a catback system.
When I looked for the cold air intake all I could find was for the 2.5 L not the 1.8
Do you have a link or a website for me so I can get started.
Thanks Robert.
Unorthodox Crank Pulley
Hi,
I found this list very useful. I had already worked through the first few mods, but it gave me some good new ideas.
On that note, I was unable to find the aftermarket crank pulley for my 06 1.8L sentra. I did some google searches and looked through the unorthodox racing site, but the only ones I found were for much older vehicles and other engines.
Any links or advice would me much appreciated.
stromung is the only one actually for the 1.8. the 2.0 hks will fit fine also.
a spec exhaust will fit with a little modification.
i'm not sure which one you're referring to, but there's great deals on b15sentra in the vendor section on pretty much all available exhausts for the b15
Powered By hopes & dreams
Discussion Starter #56
as long as it helps ya, that's my goal.
Hey Mike just wondering you said for the 1.8L sentra a hotshot header and intake will work best and can you give me a link to a cat back exhaust. I want to do these and also the motor mounts but which ones will work I saw 3 on the site ?
I have a 2005 nissan sentra 1.8L S
also wondering on where is a good place for a performance clutch and flywheel.
Discussion Starter #58
performance clutch isn't going to help you, and won't be necessary for the mods you want to do. As for the flywheel, again, for the money spent, not worth the possible gains.
You can change the Butterfly Valve either with QR20DE or QR25DE. all valves open max 85% . with this one which is bigger you have more air.
Sorry for my English. i hope you understand what i am saying.
great guide, i wanna actually follow it, but i could use specific parts and places where i could get them
just bought a 06 sentra, i need all the help i can get with it
thanks!
41 - 60 of 64 Posts
