1 - 9 of 9 Posts
Hey guys, I have started a small project and have been gathering some parts and research for some time now. Finally it has started coming together. The Project is about turbo charging a Nissan GA15.5DE. The block is a 1999yr GA16DE and the head is a OBDI GA15DE and I'm using the 1999yr GA16DE intake manifold with injector rail and TB.
The parts allocated for the build are: EMU: Greddy Emanage blue with 3 BAR MAP sensor, injector harness, ignition harness and USB support cable. Turbo: Garrett T28 (from skyline). BOV: Turbo Smart Vee Port. Fuel Pump: JECS (RB20DET pump). FPR: Mallory Ignition 4305m. Air filter: K&N cone filter. Turbo Manifold: Custom made (40 schedule steel). Oil lines - Braided stainless steel lines. Intercooler: FC RX7 stock IT. Injectors: 370cc side feed. Radiator: double core copper/brass. Fan: slim line turbo fan (for radiator). Spark Plugs: NGK IX (heat range 6). Muffler: 2.5" in (free flow).
The combustion chamber compression was dropped and the exhaust ports were ported for better flow.
The engine is going in to a Nissan Sunny 4WD B14. Pictures will be uploaded in time to come.
2018 Nissan Pathfinder SL
Where are you located ?
Project looks like fun and a lot of work.
If you are using a GA16 block is the capacity 1.6 now?
What is the difference between the 1.5 and 1.6 Just bore ?
B14 sunny ? aren't Sunny's N series, mine was an N16, Left Rand drive or Right hand drive.
good luck
yeah the block is from a 1.6l but the head is a 1.5l and stock ECU so i calling it project - GA15.5DET. The difference between the 1.5l and the 1.6l is bore 73.6mm vs 76mm. Yes B14 sunny and right hand drive (japan import).
Where are you located, Singapore ? Malaysia ?
Thanks for the Pics, i was going to ask what manufold you were going to use, but i see its simular to the hotshot.
made locally ?
maybe we should get this thread moved to the GA16 section
1 - 9 of 9 Posts
