My security system won't shut off. My remote hasn't worked for awhile. The funny thing is I open the door this morning and nothing happen, but when I open the door this afternoon the alarm went off. I tried starting the car to see if that would shut the alarm off, but my car wouldn't start. I thought the battery might be bad so I try to jump the car and nothing happen. I'm wondering if the alarm has some kind of kill switch I need to reset. You would think by using my own key I would be able to disable my alarm. After awhile the alarm shuts off, but as soon as I open the door it comes back on. I would appreciate any insight one might have.
Thanks,
Cory
Thanks,
Cory
Probably a bad door switch on the lock cylinder. Either get a remote and progmram it or fitx the door switch.
I fix the problem. I had to reset the alarm by locking and then unlocking the door. I did not try that before, thought if I started the vehicle with my key it would shut off. So the easy solution was one I should have tried at first lock then unlock my door.
Try opening the trunk when the alarm goes off. This should disarm it.
