i'm trying to change my belts in my 2000 Nissan Sentra GXE QG18de. i've loosened both the lock nut and tensioning bolt on the power steering pump pulley and the belt still wont loosen. the serpentine belt was super easy to loosen and remove from the idler pulley. not the same with the other belt. any tips or tricks? i see the pulley is slotted and am wondering if i need to remove the bolt behind the pulley on the tensioner plate.
:balls:
Discussion Starter · #2 ·
ok i got it. theres a 3rd bolt that the hayes man. doesnt tell you about. its the pivot bolt on the backside of the powersteering pump. loosen it and youre golden. 14mm.
