another rack?
most stop leaks that work on rubber do so by swelling it, but in my experience, the seals don't last much longer after doing that. If the rack body is scored, then it won't work and it will probably weaken the seals in the pump as well.
You might check into a reman. since the FSM doesn't indicate that the rack is serviceable (do not disassemble)
