I paid 150 for a sr20det power steering pump and bracket. I got all the DOHC lines and reservior from a junkyard before hand so I could complete the system. The pump I received bolts to my sr, but the line and bolt won't go together. The bolt for the pump I received is too big. I'm guessing I was sent a sohc usdm pump. I was thinking about machining out the dohc line to make it work, regardless of whether the pump I got is jdm or not. I need power steering! I have heard of people using usdm pumps on the sr motor. Hopefully they did what I might have to do. What does it sound like to you?
