Your Motor/Track is just stuck... With the Battery disconnected, carefully use a little strength to move the upper arm side to side and just a little bit on the track.180slider said:how can i fit my power seat belt and so wat do i have to do for manual selt belt?
OR disconnect the battery hop in the back seat pop the plug out of the panel that is behind the door and crank the belt to the position it would be in while you are driving with an allen wrench then you can unplug the belt control that is located in the center console (under the bin your elbow rests on while driving) if you do this neither belt will move when you open the doors but you can just flip the belt over your head and behind you when you wanna get out and the oppisite after getting in this worked for me just fine and trust me i got in and out of the car ALOT (I delivered pizzas in it lol) just a suggestion I wouldn't suggest putting alot of force on the arm when its in the forward position as you may permanantly damage the arm and/or track and get it stuck in the forward position. good luck those power seat belts are quite annoying especially when they dont work right :thumbdwn:spec240sx said:Your Motor/Track is just stuck... With the Battery disconnected, carefully use a little strength to move the upper arm side to side and just a little bit on the track.
Then connect the HOT side back up again and open the door. This should do the trick. NOW if you think it is stuck in the forward position and not coming back to the secure position, make sure the switch on the seat bottom is working. This may be the ONLY problem you have.
Replace your Door switch.. OR adjust the Micro arm VERY carefully.Vekoner619 said:Does anyone have a solution to my problem?
Thanks yo.spec240sx said:Replace your Door switch.. OR adjust the Micro arm VERY carefully.
Yet, due to poor prior care or just crappy weather and the vehicles sitting out in it, most are worn/rusted/weakened. So just replace with 1 from a Pull A Part Yard.
I've done the same (4-point harnesses) and I don't know what to do about the trim... It appears to be a contiguous piece with the rest of the door. You can remove the door trim and then remove the seat belt slider, like I did, or just cut it off with a sawzall like my lazy friend CarbonKyle did. Let me know what you figure out!KaRdoN said:im just going to rip mine out and put a harness in there, anything special i have to disconnect? and where can i get the trim peices to cover up the tracks?
