1 - 11 of 11 Posts
Ok guy's still hunting for the elusive issue that has so far evaded my technical expertise!Lol... Just what sort of issue does a problem with the egr valve and or the solenoid on the emissions canister??? As of now the car has a new issue that has only has lead me in this direction,it's the idle. I have noticed that the idle has been a little bit higher than I like and also is jumping around a bit? So I decided to try and trim it back well I was unable to do it and this leads me to believe that I might have some sort of vacuum leak or egr issue? I still have the miserable hard start issue and the performance is getting worse! If i have more than two people in the car it can barley get out of it's own way.....Someone has to have had something like what I am going through happen to them? Zero codes??Anyone have an egr problem with these symptoms?????
idle air controll valve, take it out and clean it with carb or brake cleaner......its on the left side of the intake plenum it has a purple plug on it
Thanks but been there done that already! As I said I have done all of the things that are typicly wrong with this engine and now I am stumped?? I'm thinking that it might be an egr issue at this point?
well delete it and see if that fixes anything... Have you been able to check the ECU yet?
did you check the maf? make sure the tubes around it are sealed correctly
OK, here is the problem. Under the plenum (top part of manifold) you have the Air regulator. this is a black and silver alluminum part that has 2 hoses coming out of it. Its bolted to the lower plenum with 2 10mm bolts. I had issues with mine holding the idle even when I hit the gas hard. it held the RMP at 2000 to 2500. then all of the sudden it would finally lower it. I replaced it and it was fine.
I will give you the Courtesy parts link here:
CourtesyParts :: [22660M] IACV-AIR REGULATOR - Sentra (B13) 11/1990+ 2.0L NX2000 5-Spd M/T, 08/19
see what engine and application you have, manual and automatic are different. I had to change mine when I swapped my automatic tranny for the manual
Chris 92 classic
[email protected]
For the EGR delete there are walk throughs online but I havent been able to find a single one that covers everything. Alot of posts to get all the info I wanted. Still looking for a few other things.
Man I have been trying to find pne of the first posts again for a bout 3 months. Its a PITA.
1 - 11 of 11 Posts
