piston removal
1283 Views 6 Replies 3 Participants Last post by  pete?
how would one go about romeving the piston from the AD22vf caliper?
1 - 7 of 7 Posts
According to the FSM, it is removed using compressed air.
Remove the caliper
Remove the bleeder valve
Place a piece of wood in the cylinder body to stop the piston
Put compressed air in the bleeder hole.
Remove the piston seal with a suitable tool.
Both the piston boot and piston seal must be replaced when reassembling.
Lew
i can buy the boot and seal from the dealer right?
Perhaps. I would try Courtesy Nissan in Dallas.
I think the part number is 41120-11L27
It is a caliper seal kit.
Lew
out standing, thanks
An alternative method for removing the caliper piston from the front calipers is to take the brake line screw out, insert a long M8 bolt in through that hole, and tap it lightly with a hammer. If you put something soft (like a rubber sheath) on the end of the bolt before you insert it, it will prevent the back of the piston from getting scratched. I prefer the compressed air method to this, but it's handy in case you don't have access to a compressor.
NAPA also sells the piston seal and boot as a "seal boot kit".
^ you know, that sounds like a great idea! ill figure something out.
1 - 7 of 7 Posts
