1 - 8 of 8 Posts
I have a couple related questions that I’m hoping someone with experience can help me with.
My main issue with my Armada is that some component is out that won’t let me operate any of my radio controls or my front climate system controls. The screen of the radio boots up when I start the vehicle, shows the Nissan start screen but then it just goes to the last screen it was on before the issue started. The blower is always running when the vehicle is on and I can’t change the speed or temperature. The strange thing is that a couple times everything started working for a while and then it craps out again. It’s been out now for several months. I’ve read multiple things on various forums about the same issue but no one seems to have a straight answer on which component needs to be replaced (even though this seems to be a pretty common problem). So, my first question is just that…what is causing this and what do I replace to fix it?
One person said to replace something called the “AV Control Unit” which the diagram looks like it is behind the two 12 volt (cigarette lighter) outlets below the stereo and climate controls. I have no idea what part number that would be and trying to do more research on it hasn’t produced much that helps me. A couple other people said to check the 20A fuse under the hood on the passenger side for the radio. I looked at my fuse and it’s not blown or overly dirty.
Secondly, multiple people have talked about replacing the HVAC blower motor resistor which should be an easy thing to do from what I’ve seen. I don’t really think that will solve my above issue since that resistor is just supposed to control the fan speed but it’s a cheap part so I figured “why not?” I pulled the resistor from under my dash to make sure I ordered the right part. My problem is that the one that was in my Armada doesn’t match the one ALL the sites I check tell me to buy. Mine has 5 fins and clearly shows the part number is VP5NEH-19E624-AA (see images below). The one on Amazon, eBay, and other sites pull up only has 4 fins and looks shorter. When I look up part number VP5NEH-19E624-AA it says it is for a 2010-2015 Armada. Mine is a 2008 SE model. So, my second question is…do I replace it with the part every site recommends or with the one that was in my vehicle? When I bought this vehicle the tires that were on it didn’t match the size listed on my sticker in the driver’s door so I wouldn’t put it past the previous owner putting another wrong part in it.
Any help with these issue would be greatly appreciated. Thanks.
Eyewear Tints and shades Font Electronic device Gadget
Finger Wood Gas Cosmetics Camera accessory
The likely culprit for your settings not displaying is the A/C Auto Amp, which is a separate box attached to the back of the display. It's unlikely the AV Unit is responsible since your other display and radio functions work. The Auto Amp has its own fuse, #8 in the cabin fusebox, so make sure that's good. If the Auto Amp is bad or offline, it's possible that's causing the blower to run all the time, so I'd address that before assuming the VBC (resistor) is bad.
If the VBC is bad, don't sweat the number of fins on the replacement. Different manufacturers use different heat sinks, but it won't affect operation. Your existing one doesn't appear to be OE, so someone probably changed it one or more times already. When they melt short-circuit it's almost always because the blower motor is sucking too much startup current, so if that's the case, you should replace both the motor and VBC.
First of all, thank you so much for the response and help!
Does the A/C auto amp look like the pics below? I guess it’s the same thing as the “temperature control module” since that is also what the sellers are calling it. I found this one on eBay but I’m not sure if it’s the right part. Also, you mentioned that it’s unlikely the AV unit is responsible since my “other display and radio functions work” but I just want to clarify…the radio screen comes on but NONE of the buttons for the radio or climate control work currently work. I can’t change stations, I can’t change the temperature of the air coming out of the vents, etc. It’s weird to me that the radio and climate systems are connected like that but oh well. I’m not sure about buying a used replacement for it but short of going to a dealer and paying a fortune this is mostly what comes up online.
For the VBC I’m glad it doesn’t really matter if I replace it with one with the 4 fins. I never know with this vehicle what parts actually go to it or not sometimes from some of the things I’ve come across. I’ll try the A/C auto amp first and hopefully that fixes my main issue.
Thanks again for the info. It just seems so difficult to find a straight answer for certain issues like this.
Motor vehicle Bumper Automotive exterior Gas Trigger
Handwriting Font Gas Technology Electronic device
Gas Laptop accessory Composite material Font Automotive exterior
That's the right type of unit. The 27500-ZQ00A on the label is the Nissan part number. You should make sure it's a match for your ride, there are usually several variants for any given model year. I suggest going to NissanPartsDeal.com and plug in your VIN, NPD has the same dbase as Nissan DPiC and you'll get the right p/n for your specific vehicle plus the number for any supersession. You should always use Nissan part numbers when googling parts for your ride, especially electronic parts. Shopping by make-model-year is just about guaranteed to give you a headache.
BUT, If none of your buttons are responding then it changes things. It's possible the front switch panel has gone bad, and yes, the AV Unit also. The way the controls work on an early Armada, the A/C switch panel has its own "brain" and talks to the AV Unit on a LIN line, the AV then passes the info to the Auto Amp via the CANbus. If the Auto Amp needs a change in the display, it then sends a command back to the AV, which is in charge of the display. So any one of the three could be responsible for your A/C problem. Given what you say about it not responding to radio buttons, I'd be inclined to suspect the AV or the switch panel. Check all your fuses with a test lamp, not a visual inspection, including any fuses marked "audio" in the Fuse & Relay Box under the hood. There are multiple fuses which feed the AV and Auto Amp.
I bought a test light off Amazon and got it in yesterday. I have a good multimeter and I have checked fuses with that before but the test light seemed quicker/easier when I watched a few videos about them. I just went through all of my small fuses in the cabin of my Armada and the fuses in the engine compartment. There are some large fuses under the hood that I’m not sure how to test and probably don’t need to anyway. The only ones that showed no signal was one under the hood for my fog lights (which weren’t turned on at the time) and one by my glovebox for something called the Auto DRPO which I’m not sure what that does but the fuse isn’t blown and I even pulled the fuse and checked the connections on both sides without the fuse and there is no power going to that spot anyway. I read one forum where another Armada owner was saying he didn’t have a fuse in that spot at all.
So, I don’t think it’s a fuse problem I guess I’m going to need to pull the dash apart for the A/C switch panel, the A/C auto amp, and the AV unit like you mentioned and see if it’s any of those.
Thanks for all of the info and for that Nissan parts website (which should come in really handy). I don’t know if there is but it would be nice if they had parts databases like that for every manufacturer. I’m going to take a look at my parts and check that website to cross reference each one. Hopefully, I can find the cause without blowing a ton of money. Last resort will be taking it to a mechanic if I can’t figure it out. It’s an old vehicle so I don’t want to invest much more money into it that I’ll never get back. It has over 200K miles on it.
Thanks again…I really appreciate it!
OMG! I just fixed it! Since you were saying it could be one part or another I had an idea to look on eBay and see if anyone was selling the whole radio/climate control bezel with the parts I needed to possibly replace still attached (see images). I figured if someone was selling one like that they would inflate the price since I’ve seen small, used replacement parts sometimes sell for ridiculous amounts. I found a listing that had what I wanted and the guy was asking $235. I talked him down to $200 even. I received it today and installed it after I was off work (I already had the old unit out of my car earlier last week). After reconnecting everything I noticed that my radio display screen now showed “no disc” which it hasn’t shown anything different for many months. I turned on my stereo and I was SO relieved to hear it come on. I then tried the blower and nothing happened. I was puzzled for a sec but then I remembered I took out the VBC last week and it was sitting on my desk in the house. I went in and got it, hooked it back up, and the blower kicked on! Everything is now working like it should. I’m not sure if I could have fixed it any cheaper but for me I’m completely satisfied spending a couple hundred to fix an issue that has been plaguing me forever. I know for a fact if I would have taken it to a mechanic I would have spent way more.
One thing I should mention is my A/C auto amp/temperature control module does not look like the previous one I pictured. Mine doesn’t have turn knobs attached to it. Mine is just a circuit board behind several push buttons.
Anyway, thank you so much for all the help (including the Auto DRPO fuse explanation). You helped me a ton!
Vehicle Plant Communication Device Steering wheel Audio equipment
Computer Circuit component Electronic instrument Computer hardware Gas
You're most welcome, glad I could help. Sounds like the "keypad brain" in your front panel was fried, so none of your keypresses were reaching the AV Unit. That could be easily diagnosed at the dealership because the AV would be throwing "no comm" codes for the front panel, but it isn't so easy on a DIY basis with no scanner to read the AV. Good job!
:) (y)
1 - 8 of 8 Posts
