Hey folks,
My 2008 Pathfinder's front wheels seem like the diff is locked/broken when in 4WD and 4WDLO modes. Turning sharp corners I can hear and feel the tyres churn against the road because they're not spinning independently. Is this just how the system works? or is there something broken down there?
thanks in advance for the advice :)
06 Se model
When in 4WH front wheel pull to the right. The tire image also has the tires aligned to the right. Following...
Welcoming to the forum.
I’m sure someone will be able to help you.
[/QUOTE
NF Mod/Nissan Master Tech
The 4WD display always has the wheels turned to the right; that's the way it's supposed to be. As to why your front wheel pulls to the right when in 4-HI, is another thing. You might want to do the usual checks: play in wheel bearings, sticking brakes and wheel alignment or tire wear. As to why it would only do it in 4-HI is beyond me?!
