This is probably the easiest thing I have ever done. I think my 6 year old son could do. I had a screw in one of my new tires and this fixed it. Takes about 10 minutes. Pull wheel, pull out screw or item, and take tool and punch it in and out a couple of times to clean the hole out. Then you take the other tool, run the plug threw it, and punch it in and out. Piece of cake. Obviously you have to take the wheel off to do this. A good trick to small holes, is to get a bucket of soapy water and use a sponge. Rub if over the tire with the air filled up and it will find it. These kits are like $5 at advance. Here's a similar one:
