P1140 and Intake valve timing control position sensor
23K views 3 replies 1 participant last post by  sentra368
#1 ·
My 2002 Sentra has just under 100,000 kms on it, and a few days ago, the "service engine soon" warning popped up. I took it to a shop, and the error code was P1140.
After consulting the factory manual, it appears that the "Intake valve timing control position sensor" or "Intake valve timing control position solenoid" needs to be replaced. Is the aforementioned part reffered to by some other name, as i can't seem to find a part number for it? Most likely, i will not be getting the original Nissan part.
Also, any advice regarding the replacement would be appreciated. I have driving the car around a little bit in the meantime, and i haven't noticed any other problems.
Between, the mechanic at the shop wanted to replace the O2 sensors.:rolleyes:
#3 ·
