Nissan Altima, 2005, 3.5 lt., SE model
I have a miss in my motor (car has 80k miles) on it. I was getting a general code, P0300 (random misfire, general). So, I removed the intake and replaced the spark plugs and coils. Then I drove it. It ran great but about 10 min. later, I got he proverbial "Service Engine Soon" messge.
Got my ODB scanner, read the codes and it now saying P0302 (Misfire cylinder 2). So, I swapped coils (2 with 4) and stll got the code. Swapped spark plugs (2 and 4 again) still getting the code.
So, I said "What's Next?!" I ordered a set of fuel injectors, becase the engine smelled like it was running rich - maybe it's a fouled injector? Went to start that job and then I noticed the electrical connector on Cyl. 2 looked different than the other connectors. I posted pictures below. The 1st picture is the bad (odd) connector on cyl. 2. The good connector (cyl. 4) is the 2nd pic.
Questions:
1. Do you think the connector could cause the misfire/code?
2. Can these be ordered and replaced?
3. Anything else I should look at?
Thanks for any input, this group is great!
Pictures:
Bad Connector
GOOD CONNECTOR
Questions:
Pictures:
Bad Connector
GOOD CONNECTOR
