I recently swapped engines from a 94 model to my 96 Altima. Here is the breakdown. Perhaps someone can offer me some advice please?
Symptom: Gauge registers, but after a minute or so, the temp gauge hits hot. The exhaust blows a little grey/white smoke, bt not that bad (smells like burnt oil), but car still purrs like a cat. No misses or strain.
Repairs: Replaced the water pump and did a "trouble shoot" on the cooling fans. Both fans work properly (HI-Low) functions properly.
-Flushed radiator and block, replaced with 50/50.
-New radiator cap
-replaced Coolant temp sensor
-replaced thermostat (170deg)
-No water in oil, valve cover cap has no residue buildup.
Could this be an indicator of a blown head gasket?
No compression test done yet.
Thanks for reading,
