I a brand new tensioner pulley and the belt is just right, the flex is only .5in just like the book said. any other ideas, it sounds like my power stearing pump?♣Zen31ZR♣ said:Did you install a new tensioner pulley? Mine was making approximately the same sort of noise, and also had a brand new pulley. Make sure you didn't over tension the T-belt.
♣300zx♣ said:I a brand new tensioner pulley and the belt is just right, the flex is only .5in just like the book said. any other ideas, it sounds like my power stearing pump?
Mine made that same sound and it was full. The sound may be caused by a loose belt, try tightening that first.♣AsleepZ♣ said:Check your fluid. Mine is doing the same thing and it means she's thirsty.
♣Zen31ZR♣ said:Mine made that same sound and it was full. The sound may be caused by a loose belt, try tightening that first.
No, him, not you.....♣AsleepZ♣ said:My belts are fine. Brand new and tight. She's thirsty, because when I filled it up today she settled down.
The belt is just right, I think its the bearing in the power steering pump.♣Zen31ZR♣ said:No, him, not you.....![]()
