1 - 8 of 8 Posts
Ok so a 1997 200SX SE-R w/ SR20DE......does it have a oil pressure sending unit or a oil pressure switch?? I want to install an oil pressure gauge. Anyone have an experience they might wanna share??
Thanks
DUH!!!!
Ok i guess im an imbecile..........im a mechanic that thinks there is a possibility of a pressure sending unit on a car without a gauge!!!! obviously theres a switch.......now to find where it is!!!!
Thanks
ex-Super *********
I havent really seen where the switch is, but I can tell you that on a GA it is close to the oil filter.. Wait I have a book here..Hold on..Damn, not in there.. If you want to intall a guage I would bet the switch on the SR is the same as on a GA. You can either take the switch out and replace it with a 1/8"NPT sender, or you can make a "T" out of 1/8"NPT stuff found at your local hardware store. This way you can retain the stock"idiot" light. One other option is a Greddy oil filter block with sender ports or a set-up like I have(Its on my site). Hope this helps.
Re: DUH!!!!
Thanks
Its directly above the axle support on the passenger side. Besides the starter, its the only thing back there with a wire on it. The best thing to do it get a quality T fitting, and keep the stock light. The sending unit, and the hole are 1/8BSPT, and most aftermarket gauges are 1/8 NPT. These are close, but they are not interchangeable. You will need an adapter.
Thanks for the help......im probably going to attempt getting everything installed and wired sat morning so.....wish me luck!!!!:D
1 - 8 of 8 Posts
