I have this major oil leak problem it seems like it come from all over the buttom of the front end......I use syn oil just to let u guys know.........I have replace tranny and engine oil pan gasket and oil still coming out slowly.......By now I just iqnore it and refill it after a while and let it leak.......beside additives do u know where are the loss edges that leak oils under the engine?
I had a similar leak until last night. A friend of mine and I replaced the front seal and used a "repair sleeve" (<---not sure of the technical name) on the crank pulley/balancer because it had grooves worn into it. Stopped the leak altogether. I had oil everywhere on the underside of the engine around the oilpan and everything. It was from the balancer slinging the oil everywhere over time.
Still moderating..sorta
Switch back to dino oil. It might stop/slow the leak
