Hey guys... i seem to have a leak coming from the top of my valve cover. Covers the top of the valve cover in oil. It seem to be coming from one of the a-corn looking nuts on the valve cover. what are these for and is there any way to prevent them from leaking oil? Pic below
B12 Enthusiast
Those Acorn nuts are what hold your valve cover on. There is a rubber seal under the washer underneath each of them. If you buy a new valve cover gasket, it should come with those seals. You might also want to check your PCV valve on the back of your intake to make sure it is not plugged. If you've never changed it, now might be a good time. :)
pcv valve is good.. replaced it in summer time... i might just end up taking out that one nut and trying to make a gasket for it underneath
Nissan Junkie
Why the gasket kit can't be more than 20 bucks just get it and replace the gasket and the seals I would at least unless you are on a real low budget that is then try your way.
