i got a ga16de with a bad oil leak behind the the crank pulley.i just got done replacing the timing cover and front seal and started it up.i let it run and noticed oil running out like water so i shut it off.i got the front seal from napa.could it be the oil pump is faulty or the seal is crappy.i got it from napa.should i get one from the dealer?if anyone has had this problem or can help.let me know.
