1 - 13 of 13 Posts
Hello, just wondering if someone here knows... i have a friend with a Civic who uses oil instead of water to cool down the engine... is that possible? i have seen oil coolers but they're for the oil system, not the normal water cooling... ideas?
Icy Hot Stunta
Don't do it, oil does not have the thermal capacity to move heat like water does.
No Nissan Yet
Re: Re: Oil instead of Water for cooling?
i second that. also, how does he cool the engine with oil? what kind of oil? i am very curious to see his setup.
freakish poster
In fact they use oil as the medium in those electric portable radiator stytle heaters because they retain heat so well, just what you don't want in a car.
Jmm, but if it retains heat then cools down thru the radiator doesn't it should be better than water since oil doesn't evaporate at the point water does? or the oil doesn't cools down faster enough??
No Nissan Yet
remember, the water is in a pressurized system to you can raise the boiling point, so that is why it doesnt evaporate. oil retains heat, doesnt dissapate it like the properties of water, but maybe their is some kind of oil out there that can? maybe synthetic? huh, who knows....
Wise Cracker
Clarification
SergioCR said:
Jmm, so i guess that the "Competition Oil Coolers" that claim to cool down the engine oil doesn't work too good....
They cool the oil itself, NOT the engine. Keeps the oil from breaking down as quickly, increases longevity, etc.....
Same concept as a radiator. The radiator cools the COOLANT so it is cooler as it circulates through the cooling system.
Discussion Starter · #12 ·
Re: Clarification
so it may be a good add-on so the oil doesn't die that fast... or at least keep it working better, doesn't matter what type of oil, i still change it at 3000mi.
Is there any problems with oil leaks on those oil coolers that i might be aware of?
bitter old man
Oil is a significant extractor of heat from an engine. Air-cooled motorcycles need air flow around the cylinders and head but also receive benefit from the heat rejected by the oil in the sump. My Bandit is designed to cool the head around the valves with engine oil and the bike has a radiator/cooler/heat exchanger (all three names are appropriate).
As for using oil as the only coolant in a car engine, that won't happen. The exchange area needed to do so isn't practical on a car. As Centurion noted, oil has a low heat capacity...which doesn't mean it can't absorb much heat but rather it won't absorb or release heat quickly like water. It would take a REALLY huge exchanger to reject the heat fast enough to keep the engine from melting stuff.
Competition oil coolers do work, but only as a means to control sump temperature in a WATER- or AIR-COOLED engine. Oil breaks down rather quickly once it reaches 250-260 ºF and this destroys its lubricating properties.
1 - 13 of 13 Posts
