I been chasing od problems on my '91 hatchback and while doing this I had to unhook the ECU . After hooking it back up the od light comes on like mormal then blinks 16 times in a row. I may have turned the key on while the ECU was unhooked, did I screw something up? What does the od light blinking like this mean? How can I fix this?
Chris90FB240sx said:
OD... Over Drive? I dont know, usually when you have a blinking light on something like your check engine or something it is a code that can be read if you know how many blinks means what.
Yes the "overdrive off" light is what I am talking about. As far as I can tell the check engine light comes on with the key in the on posistion and then gose out when I start the car. The car is an automatic.
