Purchase an 01 Pathfinder without an engine it was missing wiring harness for the positive battery terminal. Purchase a JDM Engine from eBay track down the correct harness change front and back engine crank sensor and cam position sensor no spark. Rear crank sensor is getting power 12 volts had trouble checking signal at the coil seems to have voltage even when not cranking. Any ideas would be very helpful thank you
