1 - 8 of 8 Posts
2018 Nissan Pathfinder SL
its rare to get these at an autoparts store without the torque member / plate.
No you cant use the SE-R one, no you cant get one from Nissan.
I posted part numbers on the forum here, search for them.
If you buy the loaded caliper it normally has the torque plate.
DNE's VZR Conversion
you can buy them through greg vogel at gspec performance iirch.
also full calipers as well
Liu, are you saying you can buy the torque members now ?
Please Shift Here
Any autoparts store can get you the right parts. Autozone or Discount/advance auto. You buy the loaded calipers (loaded comes rebuilt with pads and clips and typically the torque member or "Mounting bracket"). After than you just need 2 rotors.
Here's what a search brought me:
Advanceautoparts.com:
P/N 171440 (Right Caliper, Complete)
P/N 171441 (Left Caliper, complete)
As for a rotor, it's your choice what kind you want to get, personally, it's a chunk of metal. The car I selected was a 1993 Nissan NX 2.0L.
Here you are .....
i published the rotor part numbers I found when i did this, i will search and add if I can find them.
i got mine from Rock auto, yes 26 mm thick.
checked Brembo web site you have the right part number, says 26 mm, min 24 mm
part number I give for Brembo below is old.
EDIT:--------------Found this from when I was upgrading mine.....
I ordered Raybestos from this....
Part numbers for ad22vf upgrade
Rotors:
BENDIX 141794
RAYBESTOS 96280
DELCO/DURASTOP 18A517
CALIPERS:
WAGNER L126784 Lt Hand
WAGNER L126785 Rt Hand
CARDONE F LEFT 17-1441
CARDONE F RIGHT 17-1440
RAYBESTOS F LEFT RC10156
RAYBESTOS F RIGHT RC10155
AUTO SPECIALTY F LEFT 40-51090
AUTO SPECIALTY F RIGHT 40-51089
Product: Brake Disc
front (257 x 26mm) FITS:
Year Range:
11/1990-6/1992
Catalog No: N1000-34540
Brand: Brembo
Weight: 14.25
Our Price: $34.95
List Price: $115.35
You Save: $80.40
RAYBESTOS Part # 96280 More Info {PG Plus Outside Diameter 10.125" / 4 Bolt Holes / Vented}
Category: Rotor $17.48 $0.00 $17.48
Powered by natural gas
Get the NX2000 Japanese model with ABS loaded calipers and rotors. All I had to do was trim the dust shield.
1 - 8 of 8 Posts
