my car: 1991 Nissan NX 1600 Manual Trans.
ive got a weird cyclical rubbing noise coming from my front end whenever i am in gear that slowly winds down if i coast in neutral to a stop.
if im stopped completely and rev the engine, it sounds fine.
i put it up on jackstands and tested it up to 4th gear which sounds the worst but i still cant tell for sure where the sound is coming from...
is it the pressure plate? because it only spins when enganged, then slows down when put back into neutral?
the weird thing about that theory is that i would think the noise would eventually stop if i coasted long enough, but as long as ive been in gear, and i havent completely stopped yet, i can hear this noise......it seems like once the noise starts it slows down at the rate of speed that the tires slow down at...
i took off the driver side tire when it was on the stands and it didnt have any effect on the noise. i tugged on both my cv axles and they seem like theyre in there good....do i have to take everything apart to be sure the axles are in there good??
so im thinking its transmission or clutch plate but how do i tell?
also i should mention i just swapped the transmission a couple months ago and everthing ran fine for all this time.... after it started making this noise i checked the gear oil and i was down half a bottle so there is a slow leak but i dont feel like that should cause transmission failure...but maybe it was enough....
well is there any way to tell what it is without taking the transmission off again???
