1 - 8 of 8 Posts
My sentra GA16DE have 160k miles and i am thinking to install a 40hp nitro kit, but im afraid that my engine broke !
Someone can halp-me? My engine will broke if i use 40hp of nox ?
thz
· TRIPPLITE COMMAND CONSOLE
depends
on how hard you run it..
IMO
but why only spray?
do other things and be like and read the NPM thread
http://www.nissanforums.com/showthread.php?t=30
its long.. i only got to like the 46th page or so and couldnt read anymore..
good stuff they did to the 1.6L beast.
last i read was 233.7 WHP
(insane)
but look more into the nitrious thing.. cause i dont plan on sprayin till my car is nice and bulletproof LoL ( once i get it running hahaha )
IMO
but why only spray?
(insane)
i prefer nox because i need something easy to install/unistall and spray isnt a permanent mod.
· Towards Antisocial
check the compression of the engine, change your plugs, etc.. if everything is in good running order a 40 shot should be ok. Personally, I wouldn't do it if you have to depend on the car as a daily driver though. ;)
why? If i dont spray, the car will be the same...
· wont go any faster?
hes saying as if you spray and you blow the motor. also from the reading up that i have done the only kit you can run safley is a wet kit that injects gas and nitrous at the same time. a dry kit that only injects nitrous will fry the motor. also you wont get mutch gains out of it unless you have the other boltons first wich is why im not putting mine on yet. go to the nitrous and forced induction and read up on what otehr people have done
· Nitrous Junkie
RESEARCH
i have 108XXX miles on spray and no problems get a compression test and see if your injectors and fuel pump are up to par and you should have no problems.
Bryan200sx said:
RESEARCH
very cool your car !! i realy liked =] Unfortunely here (Brazil) dont have any nice nissan like your car ! Only the B13s, P11s and Maximas.
Thz for de help ppl.. i will start the tests of my engine, and if all ocours ok NITRO THEM !!
1 - 8 of 8 Posts
