This car wouldn't start after getting gas one day. I pulled up, filled up and then tried to start it to leave and nothing. It cranks, but won't start. I put a new timing chain guides tensioner etc on this car. New dist cap, button, and even tried a different distributor. I have also tried a diffrent coil. The car seems to crank slower than it should. Could this have something to do with my starter? The engine doesn't even really try to start when I crank it over. Also, if someone could scan me the pages for the timing chain install from a chilton or haynes manual so I can make sure I have it in time, and send it to [email protected]. Thanks. Also, where is the IAC located on this motor and could it cause the car not to start? Does the IAC have "AAC Valve" on it or is that another valve? If not the IAC what is that valve? Also could it be bad gas even though I just filled it up could that new gas cause it to not start so soon? Thanks and sorry for all of the questions. Any help would be appreciated.
