1 - 8 of 8 Posts
I have a '97 Pathy, and the bearing on the pulley in front of the compressor is making a constant grinding noise, whether the clutch on the compressor is engaged or not.
I was under the impression that the pulley could be pulled off and replaced, but a local mechanic, who I don't trust, is telling me that it needs a whole new compressor. I know that's not the case, so I won't be going back to him. The compressor was replaced by Nissan under warranty at about 100k miles, about 55K miles ago, and works fine, A/C blows real cold, clutch engages and disengages no problem.
I was just wondering if it is actually possible to replace just the pulley on the compressor, without having to empty the A/C system, pull the compressor off, and then re-charge the system?
Thanks.
first thing...
look at it. can you pull it off after taking off some bolts?
2nd..
get a print out at the dealership of your yr, make, model's A/C Compressor.
3rd..
i'm sure it can come off, but like you feared.. may need to come off the car so you can see what you're doing.
Yeah it looks to me like it can come off, but not sure of it can be done without pulling the compressor, which is fine, I odn't mind having to evacuate the system and re-charge. Just wasn't sure if the pulley and bearing could actually be replaced without doing the whole compressor, even though it looks that way.
Well I checked with the dealer and it seems the compressor and pulley are all one assembly, so I will have to replace the whole compressor.
Dealer wants around $900 to do it!! Yikes. There's nothing even wrong with the compressor. I am pretty dissapointed with Nissan for making such a stpid design, and this will now be the 2nd compressor I'm putting in it.
Gonna have to go aftermarket this time. Seems insane to me to pay $900 for a compressor. How much labor can be involved, I can pull it out and back in, in an hour myself on my back in the driveway??? I mean it can't be more than an hour of labor and another for evacuate and re-charge. What a hassle.
I feel your pain.... I have the same issue on an '04. Checking the local parts store, the compressor is $470. Of course, this does not include the new 134a or the labor needed to do the swap and recharge.
apparently, there isn't even a core charge, so the old compressor won't get you any money back.
is that $900 just for the compressor or is that for everything - labor, recharge, and part?
K03Sport......The $900 was total for evacuating the system, the new compressor, re-charging and all other labor and tax.
Still trying to fiond out if I really need a whole compressor, it just seems idiotic to me. The only thing wrong is a simple bearing in a pulley.
1 - 8 of 8 Posts
