When I start up my car and go to turn the wheel to turn out of the garage there is a loud noise that sounds like a belt is squealing. I read all the other threads but I still wanted to post it because it only happens right after I start my car and then turn the wheel. After the car warms up it goes away and does fine. Just wondering if any one could help me out and point me in the right direction. THANKS!
Destroyer of worlds.
it could be the belts, you could replace them(they're cheap.) but it could also be your power steering pump having troubles. check the fluid level and add dexron III/mercon if necesary.
my pump is chattering a little, i think i overtightened the belt a smidgen...or the oil's up and gone bad on me. lame.
