Ok so Out of the blue this morning my 93 se decides it wont even try to crank. Battery has full charge, all fuses and relays are good but cant get it to crank. Havent had time to beat on the starter or try to jump the solenoid.
Will be starting the fun around 3pm and just want to try to get a list of things together to try. Have most of the threads on no starts but havent been able to get what Im looking foout of them. Any help appreciated.
Be sure to check the battery voltage while you try cranking it. A battery can appear to be fully charge, then drop to 1 or 2 volts when cranking. Usually anything less than 8 or 9 when cranking means a bad battery.
Yeah I replaced the battery in the last 6 months. Its the solenoid. Can get the car to start after jumping the solenoid. Some where the starter is freezing up and cant get enough to free itself. Oh well cant really drive till sept so not to big of an issue right now.
