Hi, I'm new on the forum!
I would like to know if someone could help me with my t30 xtrail 2.2dci issue.
The problem is that the engine has no power until 3000rpm, passing that point pulls very well.
No engine light on the dash no code. I check the turbo actuator, change the map sensor, clean the egr. The problems started after changing diesel and air filter but they look ok. Any ideas? Thanks
Sup Mod keeping the peace
If the problem started after you changed those two filters, you may have left a harness connector unplugged or dirty with oxidation on the pins.
