Ok, I have a no fuel condition. I checked the voltage at the injector harness (2 pin) and have no voltage during cranking. I assumed the ECM was bad and replaced it. I still have the same problem, no fuel. I seem to have good fuel pressure going to the throttle body, and the injector was also replaced. I also have replaced the fuel filter along the fire wall. The engine will run as long as I pour fuel down the throttle body. My ignition system is fine. I have no idea where to go from here, I'm thinking an electrical problem maby a relay or something. Thanks in advance for any help you can give me.
