1 - 8 of 8 Posts
89 HB with a z24. Blower works fine, controls work fine. But minimal heat output, and I can't really tell if the A/C works. I can't hear the compressor come on and the defrost works half ways. All fuses are OK. I am thinking the heater coil. Any thoughts?
Ok, the guage doesn't read at all, and I bought a thermostat yesterday. I am going to replace it either today or this weekend, and see what happens. If that doesn't work, what else could be the problem?
I just had this exact same problem. I changed the thermostat and also the fan clutch. My fan clutch was rusted and wasn't moving so the fan was always engaged over-cooling the radiator.
Hopefully you bought a Nissan OEM thermostat. The off-brands supposedly have issues with overheating from what i've read.
Anway, with those two things changed, my gauge goes up to just under half way now and i get good heat. I have a KA24E engine though so my gauge may be different.
If NONE of those things are your problem, it may be a clogged heater core. When you replace your thermostat, flush out the cooling system real well with the heater knobs set to the highest temperature. I even bought a special coolant system flush to get all of the gunk out.
1 - 8 of 8 Posts
