Hi Guys,
Really need your advise in case any of you had experience this before.
I am using T 30 year 2011, 2.5 VVT model.
After driving for about 15 to 20 min, the car loses power ( pressing accelerator no effect to revolution RPM) , RPM drop below 1, car vibrates......then its ok for a while hen get back to same again.
Foreman cannot detect it as there is no error.
According to foreman, he have tried to change injection coils, air fow sensor, fuel pump is also not defective.
Pls advise what can be the problem, foreman is trouble shooting for 2 days and yet cannot detect it.
Thanks
Ben
Johor, Malaysia
Very hard to say. My guess is you need to get a good code reader. If this has happened multiple times it should register a code. Could it be related to the CVT transmission overheating? Clogged fuel filter? Good luck. Hope you can figure it out whatever it is
Sup Mod keeping the peace
Could well be an intermittent camshaft position sensor or the crankshaft position sensor. The sensors are not very expense. Make sure they are a Nissan OEM product; not an aftermarket type.
Hi Ben, I thought the T30 stopped production in 2007??????? Anyways I had the same problem, turned out the EGR valve needed replacing, but loss of power can also mean a dying Turbo amongst other things. Hope this helps........
Try the transmission speed sensor
