Needless to say I have a Nissan Sentra 2.0 SE 2000 and I'm looking to change the front brake pads. I bought a pair of brake pads at my local auto shop and they seem to fit fine when I install them, however, I can't fit the caliper around the the brake shoes. The break pads just seem a little big. Maybe a few centimeters. I've pushed the piston as far into the caliper as I can. Has anyone else had this problem? I've had this issue with a couple sets of 3rd party brake pads. Any ideas? Thank you.
2018 Nissan Pathfinder SL
How did you push the caliper back ?
remove the fluid cap and use a C clamp.....
I pushed the caliper back with a c-clamp, however, I did not remove the fluid cap. I will try that and maybe that will give me the extra space I need. I will let you know how that goes. Thank you.
the piston will be almost completely in the housing when its back all the way.
press ion the edge of the piston or the bottom of the piston
